Need a little help...........
Old Nov 19, 2007 | 09:58 AM
kwackermann's Avatar
Default Need a little help...........
Now a little tuning- when I start the quad it idles at a high RPM; if ya choke it it's more normal, then after it warms up its fine. Any advice? Any pointers? Am I a little rich maybe..................
THanks
Old Nov 19, 2007 | 01:55 PM
hondabuster's Avatar
Sounds like an air leak, maybe a forgotten o ring, or clamp not tight, or intake tube has a hole or rip.
Old Nov 19, 2007 | 04:31 PM
JustRandy's Avatar
Could be an air leak like hondabuster said. Maybe it could be a plugged pilot jet??? Either way, it is definitely running a bit lean on the idle if giving it choke helps and waiting till its warm also helps.
Btw, hondabuster, those are a couple of nice observations you have in your sig there!
Old Nov 19, 2007 | 08:08 PM
Hmm- I'll check stuff out guys..........
THanks
Old Nov 20, 2007 | 05:07 PM
  #15
rv's Avatar
rv
if its an air leak take a small torch with the gass on no fire and run it around the inlet flanges if you engin changes rpm you know you have a leak easyest check to do.you can use any combustable spray to do this test also!
Old Nov 20, 2007 | 08:02 PM
  #16
Yeah- I've got a feeling the it's the idle mixture screw, I remember just B4 the valve went I could'nt get to idle for anything and everything was adjusted to extremes............
Old Nov 25, 2007 | 05:44 PM
  #17
Thanks guys- it was all a matter of jugling the idle mixture screw and the idle speed screw; the one that holds the throttle open at you tighten it. Now it runs richer than a ****, surprised I haven't fouled a plug.......
cschillo
Mar 18, 2008 07:46 PM
BigDaddy331
May 5, 2004 12:05 PM
duster
Mar 16, 2000 01:53 AM
