02 lakota
Old Jan 27, 2008 | 05:04 PM
onlybg21's Avatar
Default 02 lakota
i was just wondering if anyone could tell me exactly how to adjust the chain from the rear axle or whatever...
Old Jan 27, 2008 | 05:45 PM
JustRandy's Avatar
Default 02 lakota
I havent got that far on mine, but I know you want to keep the axle straight and have some chain slack with lots of weight on the seat. My QS the chain gets tighter the more weigth is on the seat and it kills the swingarm bearings.
Old Jan 28, 2008 | 02:00 PM
lakotaman420's Avatar
Default 02 lakota
The rear of the swingarm you'll see 2 bolts,(where the axle goes though) loosen these (make sure there loose) then the carrier is free to rotate. at the bottom of the carrier is a hole cast into it which you can insert a screw driver or whatever for added leverage. The carrier is oval shaped on the outside and rotating it increases / decreases the distance from the engine thus tightening / loosening the chain. Hope this will help you.... P.S. I feel that it is a little ezer if you take the rear caliper off just the 2 bolts holding it on then just push it up so you can get to the other swingarm bolt a little ezer. O and the lakota chain slack is 40-50mm or 1.57-1.97in from top middle
Old Jan 29, 2008 | 01:40 AM
onlybg21's Avatar
Default 02 lakota
yah i did all that but when i tried to rotate it with a screwdriver it would do anything...does the rear wheels need to be off the ground?
Old Jan 31, 2008 | 08:07 PM
nevada's Avatar
Default 02 lakota
loosen the NUTS on the bottom. then loosen the BOLTS from the top.
then it will loosen up for you to turn it.
the bottom of the swingarm is thread, as well as having a nut on it.
also, run the chain a bit tighter than normal. the lakota chain gets LOOSER as the suspension collapses. exactly opposite of other machines.
set it, then sit on the seat, it will be looser than u just set it.....
Old Feb 1, 2008 | 03:28 PM
Default 02 lakota
Yes you have to raise the atv off the ground (just the back tires). Put on a block or something in that manner.
kwackermann
Jun 24, 2015 10:18 AM
KawasakiLakota
Aug 23, 2000 11:57 PM
blazer1969
Aug 23, 2000 02:45 PM
shockwave
Aug 20, 2000 07:57 AM
cstark
Oct 15, 1999 01:45 PM
