06 BF750 NO SPARK
Hey guys. I'm a new guy so bare with me. I just purchased an 06 Brute Force 750. Ran great the first time riding. Only rode for about 20 minutes. Next day wouldn't start. Turns over and gets gas but no spark. Pulled plug to test and even hand checked the plug wire in case of bad plug and nothing. Any ideas? Hoping this has happened to someone else before I have to send this monster to the shop and you know what that means...BIG $$$ Thanks.
The 750 has a separate ign coil pack for each plug. Check the left side coil pack (as you sit on the quad) for any damage or poor connection to it. Or swap the coil pack, front and rear, and see where the problem goes to. If the rear one loses the spark after the swapping, then it is the bad coil pack. If the problem remains on the front plug, then the problem is either at the igniter or the wiring harness from igniter to the coil pack.
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
