Belt light reset info
Old Mar 8, 2008 | 10:25 PM
Kernel's Avatar
Default Belt light reset info
Hey fellas I know this topic has been drug through the mud many times but i just need to verify if this is the correct procedure for my 2006 650i Brute.
"To reset, turn ignition off and pull cvt cover. Put switch inside cover back into "on" postion. Remove seat and disconnect the 2 connectors grey and black and reverse them. They are located if sitting on quad in right rear corner. The grey one is not connected to anything, it's just a reset plug. Grey into black and black into grey. On top of the CVT cover is a black connector that goes to the switch inside the cover, disconnect that at this time. With the 2 still reversed and the black one disconnected, turn the key to the on, but don't start the quad. Observe the belt light. When it stops flashing really fast and starts flashing slow, the belt light is reset. Turn key off, and put the 2 connectors under the seat back to their original connectors and plug the connector switch for the CVT back in. Your done. "
-I got this procedure off of Nyroc. If anyone could verify this quickly i would be very very grateful. Thanks in advance, as i do not want to carry it to the dealership. -Joe
Old Mar 9, 2008 | 03:01 AM
bfb750BF's Avatar
Right But try it 1st w/o removing the CVT Cover.
Sometimes a Voltage spike will cause the Belt lite to come on or if you are at the 100 hr mark.
Unless your belt is real loose or worn out the lever inside the CVT may not have been tripped.
Old Mar 10, 2008 | 12:30 AM
Kernel's Avatar
excellent tip bfb750bf, preciate that because i didnt have to take the cover off, i done the reset, those damn plugins gave me fits lol, and reset the light just fine. Thanks have a good one.
Cummins Driver
Sep 11, 2019 01:22 PM
Shainasmash
May 8, 2017 06:38 PM
GearheadMOM
STOLEN
Aug 8, 2015 11:47 AM
toonces
Jul 31, 2015 09:27 AM
trouttracker
Jul 20, 2015 11:54 AM
