kfx400 crank
Old Mar 23, 2008 | 08:44 PM
zooooom's Avatar
Default kfx400 crank
Will a longer stroke help stop some bogging down on steep hills? This thing runs awesome everywhere except some of the hills around here are monsters. Anybody tried stroking a kfx400?
Old Mar 24, 2008 | 02:21 PM
deanz400's Avatar
maybe try regearing it to help
Old Mar 24, 2008 | 06:21 PM
DrRandall's Avatar
I honestly think stroking the motor would make it bog more if your taking it in too high of a gear. Just because the motor (after the stroker is put in) becomes more powerful, it takes slightly more time to make that power because of the longer stroke.
It really depends on how you hit the hill in the first place, and how you ride.
Too me...it seems like you are taking the hills in either too high of a gear, or not keeping it rev'd enough. Try it some more in a lower gear or rev'd a little higher.
don't take that the wrong way, I didn't mean to sound like i'm saying you can't ride or anything if it does sound that way. Just giving some advice since I have the same quad...
hopefully that helps.
Old Mar 24, 2008 | 06:26 PM
scootergptx's Avatar
Supersock
Hired Gun!
I'm with Dean on this one.
You can get a new front sprocket on ebay for under 20 bucks. And you won't be compromising the integrity of the motor.
Old Mar 24, 2008 | 07:35 PM
zooooom's Avatar
I've got a 13tooth front sprocket on it now. And I won't take any advise personally. I was on a hill saturday that has a root across the trail that you have to jump but when I got back on the ground it hooked real hard and I had to clutch it pretty bad the rest of the way up. I guess I should be happy I got up it cause nobody else did. I was just curious if anybody had tried the longer stroke.
Old Mar 25, 2008 | 09:23 AM
deanz400's Avatar
Hey Zooooom sounds like you did all right ,on my Z I usually will hit a hill in 2nd if it's not to long or will if it's steep ,other wise I'll go into it in 3rd knowing I'll have to down shift when it slows ,
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
