ignition trouble 220 bayou 1995 bad wires
Old Mar 26, 2008 | 09:54 PM
rberry3123's Avatar
Default ignition trouble 220 bayou 1995 bad wires
I am trying to get starter solonoid to work it will not click.If i could look at wiring diagram for key switch,kill and start button and starter solonoid would help. I think that some wires are crossed.help appreciated for a site or place for diagram.thanks Randy
Old Mar 27, 2008 | 02:02 PM
Hayashi's Avatar
Before anything else, check to make sure single black wire from the starter relay/solenoid is grounded to the left side of the engine (as you sit on the quad), especially where it makes a contact to the metal surface (clean, no rust, no paint, etc.).
Old Mar 27, 2008 | 03:25 PM
rberry3123's Avatar
Thanks for reply,Worked more on 220 today,I do have a ground. I can jump the 2 black wires, one comes from the start button switch to starter relay and the other black wire leaves starter relay and goes to start solonid.and it will start.there is something wrong but i don't know what.
Old Mar 28, 2008 | 10:24 PM
rberry3123's Avatar
some one has cut and taped several wires near solonid and relay
Old Mar 31, 2008 | 06:11 PM
redneckfromnb's Avatar
send me your email and i will send the info for a bayou 300,should be the same
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
ScopeZ_
Jul 28, 2015 01:44 AM
JoAnnS
Jul 23, 2015 02:18 PM
rcappie4
Jul 18, 2015 07:51 AM
Unzzy66
Jul 11, 2015 10:01 PM
