Prairie 650 vs Brute Force 650 differences
Old Jul 10, 2008 | 07:05 PM
RideRed4x4's Avatar
Default Prairie 650 vs Brute Force 650 differences
identical except for the i version on the BF and stuff 650 brute said
Old Jul 10, 2008 | 07:52 PM
bfb750BF's Avatar
Rule of thumb, don't use power washers on any of them. The high pressure water can get into other things as well other than peeling the paint off on the painted models.
I've been using "ATV Wash", then rinse it off w/the garden hose, my painted Brutes look great.
Other than the body style, the P650/BF650 are the same in the SRA Model.
Old Jul 12, 2008 | 04:38 PM
tuffEnuf's Avatar
The differences in the 650I and 650 SRA is independent suspension(650I) and Single rear axle (650 SRA). Also the engines had differences, look at the spec sheets at kawasaki. com. The 650 I had nickelsel plating in the cylenders, bigger carbs, and higher horsepower & compression piston than the 650 SRA. The 650 I also has different clutch/spring setup.
Do not know if all will have same engine in 2009. Hope this helps :thumb
Pgbama11
Jan 16, 2016 08:19 AM
fredrikrosen
Sep 28, 2015 09:58 PM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
