what kind of coolant?
I have to disagree coolant is not coolant........
If you have green use the 50/50 premix Green.(prestone)
But if you have the Pink stuff you have to keep using the pink unless you flush out you radiator and line with 50/50 white distilled vinegar / water mix then you can use what ever type that you would like. Same deal if you want to change over to any of the super coolants like Engine Ice.
jrooker6
04-23-2016 07:36 PM
1ArmBandit
55
10-14-2015 09:03 PM
