popping noise
Old Oct 11, 2008 | 10:49 PM
will0983's Avatar
Default popping noise
08 bf 650 makes a popping sound from the engine when i punch the throttle. very little power for a second.
Old Oct 12, 2008 | 12:48 AM
ATV24/7's Avatar
It is common it is the ignition retarding. An aftermarket cdi will unretard it and will also disengage the reverse overide. A DYNA-FS is a good one that is plug and play.
Old Oct 13, 2008 | 03:40 PM
Hayashi's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: will0983
08 bf 650 makes a popping sound from the engine when i punch the throttle. very little power for a second.</end quote></div>
Does it sound like air popping sound from intake/top of the enigne, or mechanical sound from middle of engine or trans area?
If it's from the top of the engine, it's the sign of too lean carb setting. Raise a jet needle a notch to fatten up.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
mrtidy
Feb 3, 2016 05:00 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
