Brute Force question
Old Nov 15, 2008 | 02:50 PM
mns's Avatar
mns
Default Brute Force question
I'm working on my counsin 2005 750 Brute Force. It has 380 miles and has sat for over a year. I replaced the plugs, drained and put in new gas. I cleaned the carbs. It idles fine, but when you apply the gas it misses bad. There is no belt light on. He also has another 750 BF that I'm getting once I fix this thats doing the same thing. I'm not familar with this machine so any help would be greatly appreciated. Thanks
Old Nov 17, 2008 | 05:06 PM
Hayashi's Avatar
Make sure choke plungers are not sticking and closes completely when choke lever is at off position.
Old Nov 18, 2008 | 08:02 PM
mns's Avatar
mns
I cleaned them with carb cleaner when I cleaned the carbs. I'm not familar with the plungers, but I pushed them in while the machine was running and she still missed when I gas it. I will remove them again , if needed. Advice appreciated. Thanks
Old Nov 19, 2008 | 11:59 AM
Hayashi's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: mns
I will remove them again </end quote></div>
Hope you are not talking about removing the carbs. Choke plungers are on the left side of the carbs at each end. BTW, you need to do some plug reading and find out whether your quad is running too lean or rich.
Old Nov 20, 2008 | 06:04 PM
mns's Avatar
mns
I checked the plugs. Their new but the back was clean, and the front was totally carbon up. Is it possible that theirs a bad coil. Thanks
Old Nov 24, 2008 | 01:21 PM
cdowden3691's Avatar
when you say you cleaned the carb's, did you also remove the jets and make sure they were not clogged?
Old Nov 24, 2008 | 11:11 PM
mns's Avatar
mns
I removed the main and pilot jets and sprayed cleaner threw them. Then I took a entire can and sprayed the floats, plungers, and anything I could see. I didn't mess with the ends with the black covers (diaphragm?). Thanks
Old Nov 28, 2008 | 02:35 AM
jamakn's Avatar
can one ask,
what happeneed to the machine to requrie all this?
Old Nov 28, 2008 | 09:33 AM
mns's Avatar
mns
My cousin is overly generous to who can ride his machines. He probably has put 50 of the miles on. His teen age boy and his friends the rest. I, nor he knows how the machines where rode. The machine I'm working on looks clean and not outwardly abused. Thanks
Old Dec 7, 2008 | 02:29 PM
TerryinWisconsin's Avatar
Did you get this solved? If so could you tell me what you did to fix it?
I am having the same problem. My 2005 Brute Force sat for 8 months and idles great but backfires through both carbs when throttle is pushed.
