Need help timing my brute
Hey guys I have tore down my brute and now am going to rebuild and I have the manual that tells how to time it but Im just a little confused about it. Can anyone help explain this or show pics of it done? I dont want to put it back together and then it be out of time. Thanks guys
The problem that I have is the manual tells me that the engine needs to be at top dead center at the end of the compression stroke. How do you know where this is? Is it there when you line up the TR and TF mark on the crankshaft? Im guessing these marks mean Top Rear and Top Front? Thanks for helping man
1. Set to TR mark on the crank at the inspection hole. Yes, R is for the rear.
Then set/align the 2 lines on the REAR cam sprocket.
2. Turn the crank end CLOCKWISE 270 degrees.
3. Set to TF mark. Yes, F is for the front.
Then seet/align the 2 lines on the FRONT cam sprocket.
Once you all do that, turn the crank by hand slowly and make sure valves don't hit the piston.
Ok Im going to try it this weekend. I pretty much knew how to do this except for the part where it talks about having the engine at the end of the compression stoke because it may bend the valves. I just wanted to be sure about it. Thanks alot man. By the way, what if the valves do hit the piston?
