2002 650cc (I think it was the first model year) reliable?
Old May 20, 2009 | 07:24 PM
Shifty12's Avatar
Default 2002 650cc (I think it was the first model year) reliable?
Hi. I am looking at a used 2002 650. I think this is the first model year for the 650. I was wondering if they are reliable and if it would be a smart purchase. I also am looking at a 2005 model also. The older model is cheaper and it has less than 3000km. It is in really good condition. The 2005 is in good condition also but is about $1500 more. Should I just get the newer model or would the 2002 be OK? Thanks in advance.
Old May 20, 2009 | 08:56 PM
KQ400Pilot's Avatar
"Hi. I am looking at a used 2002 650. I think this is the first model year for the 650."
A 650 what? Polaris? Buick? Honda? Ford? Kawasaki? Suzuki? Toyota? Chevrolet?
What model?
Old May 21, 2009 | 09:45 AM
Hayashi's Avatar
There is not much difference between 2002 and 2005. The belt has improved a bit so you can easily upgrade that if needs to. I would get the 2002 for $1500 less.
What model?
Did you want to ask "what brand"?
My guess is:
Kawi - since this is Kawi forum.
Prairie 650 - since it was the only 650 quad from Kawi that year.
Old May 21, 2009 | 01:44 PM
Shifty12's Avatar
Yes it is the Prarie. So no real issues with the older machines? The machine has been used for hauling moose. How many kilometers before I would need a belt?
Old May 21, 2009 | 05:34 PM
Hayashi's Avatar
It's like asking, how fast can you spend $100?
The CVT belt on a quad can last only 1 km or 10,000 km. Actually you can burn the belt and shred it into pieces on your first ride if you try hard enough. Get a service manual and inspect/adjust or replace the belt if out of spec. The key to long life of the cvt belt is "proper usage, menaing no slippage".
Old May 22, 2009 | 09:40 AM
kbar55's Avatar
Default 02 Prarie
Bought my 02 650 Prarie in July 01. No Problems. Did replace battery and got new tires . I suggest that if you going 12 miles per hour or less use low gear. Really saves the wear on the belt.
Old May 22, 2009 | 11:40 AM
Hayashi's Avatar
Good testimonial about the 650 and CVT belt.
Also, whenever you are towing anything, use LO gear. I even use LO gear whenever I am in 4WD mode and/or going up steep hill.
The CVT Belt lifespan is exactly proportional to your IQ level.
Old May 24, 2009 | 07:14 PM
fastestrider's Avatar
hes talking about a 2002 praire 650.(i think) if you are then go with it i had one and put over 1200mi on it and only needed basic maintanence plus it was very reliable. Hope that helped.
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
yambam13
Jul 4, 2015 01:49 PM
Jun 10, 2015 12:55 PM
