Need wiring diagram for a 1999 Kawasaki Bayou 220
I reciently traded for a Bayou 220 and the electric start wont work. It would be great if someone could send me the wiring diagram so I can trace down the problem. Using the recoil backup is getting a little old
I have a diagram that might help. Provide me with your email and I'll send it in .jpg format.
Regards,
Jim
rjestes@gmail.com
Regards,
Jim
rjestes@gmail.com
I figured out the problem. some one replaced the starter button with a different one and the wires they used to hook to the solinoid were not big enough. I replaced them with bigger wires and now it works fine.
If yes, you have a poor starter solenoid ground connection problem not providing 12V to the starter motor. Follow the black/gnd wire from the solenoid and see where it is attached to the engine/frame. Remove the end (bolt hole) of the wire and clean/sandpaper really well where the wire bold hole end was grounded. Now the satare will start good.
1999, 220, atv, bayou, cheap, diagram, electrical, installation, kawasaki, manual, polaris, regulator, regulators, voltage, wiring
