250 bayuo ONE TIRE ISNT SPINNING. HELP!
Old Jan 8, 2010 | 06:54 PM
trx250ex&250bayuo's Avatar
Default 250 bayuo ONE TIRE ISNT SPINNING. HELP!
Aliright i have a 2003 kawasaki 250 bayuo and when i give it gas only one tire spins. Does anyone know what might be wrong and on if its hard to fix and expensive?
Thanks
Old Jan 8, 2010 | 11:47 PM
NewportHillClimber's Avatar
you have to take your rear end apart. you have something wrong with your final bevel gear. and yes it can be expensive. Fiche Parts
Old Nov 25, 2011 | 10:08 PM
country1983's Avatar
check the hub on the tire that is not spinning these atv's are know for the splines going on them
Old Nov 28, 2011 | 09:43 AM
Hayashi's Avatar
+1.
the weld on the hub breaks because water sits in the hub.
Easy fix. Just have it re-weld where it broke off.
Nothing wrong in the rear bevel gear case area.
Alex G.
Sep 11, 2017 11:38 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
