1999 Prairie 400 Carb adjustments
Can anyone enlighten me on what can or cannot be adjusted on the carb? The only adjustment that I can find is the needle on the bottom, is that it? if so, where should it be set?
Thanks for your help!
My manual, says, Idle speed adjustment=Engine running and warm, turn the idle screw to obtain the slowest smooth idle speed. Pilot screw adjustment=Turn the pilot screw all the way in until it seats LIGHTLY. Then back the pilot screw out 2 turns. Hope this helps. NorminN.B.
Just took it for a test run and still not tolerable under acceleration. Can you point me in the direction of the manual you refer to, my owners manual does not refer to any carb settings. Is there anything online?
It had been sitting for a while and would not idle, but would run great on "Choke". I soaked the carb, blew it out and now it idles great but spits and sputters under acceleration. I will try adjusting again, its just very hard to get to.
micheleLeigh
Jul 12, 2015 02:50 AM
1999, 400, 99, adjusntment, adjustment, adjustments, air, atv, carb, carburetor, idle, kawasaki, praire, prairie, prarie, screw, wont
