Question about Bayou 220
Old Oct 14, 2010 | 09:42 PM
  #21
himsa169's Avatar
generally speaking i have found that if you hit the start button and it clicks its bad battery and if like ludador said it hums its starter when it does nothing its a solenoid issue.
Old Oct 15, 2010 | 07:42 AM
  #22
teeb's Avatar
I agree with HIMSA169. That smoking issue is not good. I'll bet the starter is toast. I read up on my manual when I replaced the flywheel on mine to check the starter clutch. That if it hangs it will tear up the starter. Not sure what that is like but a starter/alternator repair shop might be able to test your starter. Otherwise if you go to a dealer shop they will want to start ordering new parts. Good luck.
Old Oct 20, 2010 | 08:21 PM
  #23
LongBeard Express's Avatar
Bad grounds and bad + connections are probably the cause of the smoking. I would go through and clean ALL the conections with a wire brush.
Ryan
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
rcappie4
Sep 9, 2015 07:04 PM
