2002 prairie 300 4x4 melted wiring harness
The 300 has an electric carb heater just below the carb for easier cold starting. If the (+) wire for the heater rubs against some metal around there, it usually blows the main fuse. Not knowing why fuse keeps blowing, people put a higher amp fuse or even a paper clip or metal piece, then there you go - melting the wiring harness.
tank10rnk
08-10-2015 08:19 PM
