valve clearance for 89 bayou
The test I do is this! Remove solenoid from quad, get two paper clips and small gator clips and these on the small terminals, than hook up an 12 volts batt to gator clips, than an volt meter and set on ohms or buzz box an put probes on the two larger terminal, okay now when the batt.clicks the solenoid you should have conutity or the box should buzz if solenoid is good..... Hope this helps...This works great for me....
Scooter's Shop
23
Oct 22, 2015 07:04 PM
