650 BF seized engine!???
Old Nov 13, 2011 | 06:52 AM
vincentdrivingfool's Avatar
Default 650 BF seized engine!???
just went to start up my 05 650 bf, it winded over for about 2 seconds and stopped! pull cord also seized. could the starter be stuck? engine was cold upon trying to start. last ride went fine with no appearent problems. 6800kms,,oil is fine. HELP!!!
Old Nov 17, 2011 | 07:20 PM
Kerbbirds's Avatar
take belt cover off and see if belt broke or something else is stopping motor
Old Nov 18, 2011 | 01:28 PM
Hayashi's Avatar
If the CVT belt is in good shape and the engine still would not turn over easily with a good battery, remove the left side generator cover and using a 17-mm socket try to rotate the crank CCW with the spark plugs removed. If still hard, you have an internal engine issue obviously.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
