Utility quad to not be embarressed by sport quads
I haven't really shopped for quads in 12 years but I've looked at them.
The Polaris Sportsman caught my eye.
My concern about it and most of the others is I want a quad that I can run over small trees with, and also not be afraid to rub past trees with the fenders scraping, AND, to be able to jump logs in a single bound.
I mention logs because with my Kaw Prairie 400, it has metal floorboards and I frequently high center on the metal, then the rear wheels climb over log. with all the plastic floorboards, I worry that I'll crack the plastic, esp if it is cold outside.
The front - I have a metal tube protective framework/grillwork, oem, that performs excellent when bashing thru trees.
Fenders - my fenders have more of a rounded profile and no angles or connecting points that would snag on trees. I have a few screws on mine which hold on the rubber mud flaps, which are shiny from rubbing trees.
Those Plastic skid plates are tuffer then you think ,also they slide/slip over logs better.
I just ride over logs even if the ATV is tittering on the log, I just but my weigh forward until the front wheels touch the ground and pull you over.By then the back wheels will be climbing the log also.
Works better with a diff lock ATV so you have two front wheels pulling you over rather then one.
With a 2wd your just stopped dead and everyone has to get off and help the guy over.
Fender guards are a nice thing to have to keep things looking good.
Frisky2050
Apr 9, 2020 11:19 AM
John Boy
Jul 13, 2015 11:16 AM
