bayou 220 running rough
Old Mar 17, 2013 | 03:15 PM
lukepop789's Avatar
i do have proper airbox, and have had it on, still do. but not proper filter, im aware that it has restrictions but i have to deal with exhaust restrictions too and the original one isnt in good condition
Old Mar 17, 2013 | 11:49 PM
Hayashi's Avatar
The oem foam type filter shouldn't be too expensive.
Regardless, I'll say always start with basics.
Compression, spark and fuel delivery.
Old Mar 18, 2013 | 06:35 AM
lukepop789's Avatar
ill have to find a way to test conpression, i have spark. and i should have fuel, ill try and hook up old muffler, and buy a oem filter. i dont think that will help but def worth a shot
Old Mar 31, 2013 | 05:08 PM
lukepop789's Avatar
so i had a few days off and it was warm, i hooked up orginal exhasut, ordered a stock filter, and got a compreesion tester, im reading 75 psi on it. manual for bayou 250 says 135 to 203 psi. thinking this is my problem? or does the bayou have that much less compression?
Old Mar 31, 2013 | 05:38 PM
  #15
lukepop789's Avatar
update, forgot to check with throttle open, at 125 with it open, and 175 if i put oil in it
Old Apr 2, 2013 | 11:54 AM
  #16
lukepop789's Avatar
well if anyone cares to help, filter got here today and still didnt make a difference. its got to be a carb problem
Old Apr 16, 2013 | 11:03 AM
  #17
lukepop789's Avatar
leak down tested ok, treated with sea foam, cleaned gas again, still no avail
Old Apr 30, 2013 | 04:15 PM
  #18
Kawi220boy's Avatar
Maybe try puting a little sea foam in the gas. Mine was runing bad and it cleared it up. ??
SOLOLUCKY
Oct 4, 2024 09:09 PM
wannabe32
Jul 7, 2015 11:30 AM
rcappie4
Jun 21, 2015 07:33 PM
jgreerberube
Jun 21, 2015 02:27 PM
Smokinthebear
May 7, 2000 08:01 PM
