carb help
Old Mar 26, 2013 | 11:20 PM
Hayashi's Avatar
Originally Posted by texakaw
well i'm going to adjust valves and see what happens. it couldn't hurt may help my problem. checked all jets ,holes again berrymans will spray thru all and compressed air passes thru .gotta be clear.
When jets are clogged up real badly, spray and compressed air couldn't clean in my case. I had to use a thin wire to pass through the jet hole - mechanical cleaning!
Old Mar 27, 2013 | 06:22 PM
texakaw's Avatar
yes, I can see thru the jets,even pushed small wires thru jets,all holes in jets. I adjusted valves today didn't help.checked gas level checks ok. I rode this bike 10 days ago idle was rough top end was good.cleaned carb put in kit because it has been parked for 10-12 monthes figured it was dirty.now it idles great will not take any throttle without backfiring. bout ready to throw amatch on it....
Old Mar 27, 2013 | 08:15 PM
Jaster94's Avatar
if i remember right, richen it. it is running a little too lean.
Old Mar 27, 2013 | 09:18 PM
Ride_TL's Avatar
If everything is sealed up, filter is good, fresh gasSpam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word , and Clean Carb,Valve lash good, I'm wondering if the timing jumped, Needle setting is off if idling mint, or jetting size issue you said changed jets, fuel screw adjustment correct ? Has it ran mint sense you had bought it?
Old Mar 27, 2013 | 09:58 PM
  #15
texakaw's Avatar
I just bought the bike last month it had been setting for 10-12-months. cleaned bowel and neddle it was stuck.fired up but would not idle but would run pretty good at hi rpms. pulled carb removed all jets cleaned with brrymans carb spray all jets holes clear air passed thru everything.put in carb kit,set floats,turned pilot screw 2 turns out.fired it up idles perfect for hours .push throttle it backfires will not gain any rpm.I raised the gas level today,no help.
bout ready to throw a match on it.
Old Mar 27, 2013 | 10:52 PM
  #16
Ride_TL's Avatar
Carb kit with new jets and needle? Check the sizes and make sure they are correct, If it happened after you cleaned the carb its mostly likely something in there, mid to top is needle setting / Main jet. Sounds like its sucking a ton of air and not enough fuel. So check for an air leak, Check your pet **** to make sure it is not clogged and you are getting a good flow of fuel.
heres a Google search that may help
Google
Old Mar 28, 2013 | 06:00 PM
  #17
texakaw's Avatar
new kit with jets,needle , float needle,gasket,(spring, o ring, washer,screw).
jets have same number.checked needle jet and needle with calipers,same.
I have let it idle for hours(its running now),sprayed wd-40,carb cleaner even propane all around carb,no air leaks. I'm setting beside it now its sounds great,push throttle backfires,rpm slow trying to speed up.
new gas pit **** on tank,new filter,new line.
I am 61 years old been riding bikes all my life.still riding the last Harley I bought in 1981.always done my own repairs on bikes and cars. BUT this one is about to drive me crazy.............
Old Mar 28, 2013 | 07:22 PM
  #18
MrSummit's Avatar
Reaching here - fuel supply issue or maybe the jet needle aluminum piece that goes in before the main jet tube is installed is missing. If this piece was installed from the carb throat side, that's wrong.
Old Mar 28, 2013 | 09:17 PM
  #19
texakaw's Avatar
not sure what you are talking about. the needle jet drops in first small end first.then main jet tube ( holder) screws in and holds needle jet in place.then main jet screws into tube.
one thing I have been meaning to ask. This carb has another jet not shown in carb diagram,I have found it on other carb diagrams.its called the start jet.it screws in next to main jet tube.its clean just strange its not mentioned in manual.
Old Mar 29, 2013 | 09:22 AM
  #20
MrSummit's Avatar
On my Prairie 400 carb and my Concours carbs, there is an aluminum guide piece that the needle goes through after it goes thru the carb throat. This is called a jet in the parts diagrams. Then below that is the tube thingy that the main jet screws into.
