Mule Fuel Issue
Old Jul 22, 2013 | 09:09 AM
revy_ajax's Avatar
Question Mule Fuel Issue
Good Morning. I have a Mule 2510, KAF 620 A4. A porcupine got up undeneath the unit and chewed things up. Finally got things hooked up and turning over, but soon saw the housing on the Fuel pump was chewed through so I replaced, but still no firing. Appears there is no power to the pump now. The Porky did chew a wire coming off a fuse and I got that back together but the fuse may have popped. I do not have a listing of what fuses are on what circuits. Can someone tell me? Also there is a relay of some sort but that looks intact. Is there any other component in the system I should look at. In a thread a while back there was mention of powering the fuel system off a brown wire on the ignition as that would power the pump when the key is in the on position. Can someone confirm that as a good approach and maybe elaborate a be on this fix. Any help is greatly appreciated.
Regards
c
Aitch
Jul 21, 2015 09:40 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
ghost civic
Jul 19, 2015 10:13 AM
Unzzy66
Jul 11, 2015 10:01 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
