Air box mod
Old Apr 14, 2014 | 08:29 AM
Scott_Tx's Avatar
where do you get these replacement gears?
Old May 21, 2014 | 10:39 PM
Bayou300ex's Avatar
Originally Posted by sprinklz
you add/remove a tooth on the drive sprocket
and/or add/remove a few teeth on the rear sprocket
thats how you alter your final drive ratio
more teeth on the front ups your top speed at loss of tourqe and visaversa
more teeth on the rear ups your tourqe at the loss of top speed and visaversa
larger tires does the same as more teeth on the front sprocket
and smaller tires does the same as more teeth on the rear sprocket
put some 20s on it, or 18s. but then your 2nd gear would probably be like a 1st gear
