bayou 300 backfires
Old Oct 11, 2014 | 12:49 PM
kawasaki89's Avatar
hunter
Question bayou 300 backfires
Hi i have a 1989 bayou 300 4x4 that backfires sometimes,i put in a carb kit,a new plug wire and cap,clean the gas thank and still the same what can i do now?
Old Oct 24, 2014 | 01:11 PM
jwilson55's Avatar
Hello, not sure if i will be much help other than pose some questions to you to try and figure this out.
When is it back firing?
Is the choke on or off?
Are you coasting down hills?
My bayou 300 and 220 will back fire if i forget to turn the choke off once the engine has warmed up, or if i am coasting down hill in gear some times, acts like an engine break on a semi.
Also check your connection from your carb. to your air box and, air filter, my 300 is VERRY sensitive to air leaks in that area. if I don't' have an air filter in mine I have to keep the choke on to keep it from backfiring, so check to make sure you filter is in good shape and your hose clamps are tight.
Just some things to check hope it helps.
but kinda sound like it might be an issue wth fuel/ choke.
Good luck!
Old Oct 24, 2014 | 02:46 PM
kawasaki89's Avatar
hunter
Hi thanks for your reply,i just went out for a test drive and it is running great.
Put in a new coil.I think that was my problem.
Old Oct 27, 2014 | 06:15 AM
jwilson55's Avatar
glad you figured it out!
joe
Old Oct 27, 2014 | 10:17 AM
kawasaki89's Avatar
hunter
Glad to because im leaving in 3 days for deer hunting for 10 days.
Old Oct 27, 2014 | 10:23 AM
jwilson55's Avatar
cool, good luck hunting! I've used my bayou's a few times dragging some herbivores. they are great in expensive ATVs.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
alzgarvin
Sep 11, 2015 08:53 AM
rcappie4
Sep 9, 2015 07:04 PM
Brandon400
Sep 7, 2015 12:20 PM
