93 300 bayou clutch adjust
Old Feb 1, 2015 | 06:06 PM
acedude's Avatar
Smile 93 300 bayou clutch adjust
I have been working on my 93 300 bayou, first the nut that holds the disc on came loose and when I took it apart and found it, rethreaded the shaft, put all back together and started it up , I can see it move just a little when put in gear but will not move forward or reverse! Where do I start and what adjustments are needed???
Old Feb 5, 2015 | 03:38 AM
acedude's Avatar
I have been working on my 93 300 bayou, first the nut that holds the disc on came loose and when I took it apart and found it, rethreaded the shaft, put all back together and started it up , I can see it move just a little when put in gear but will not move forward or reverse! Where do I start and what adjustments are needed??? I am referring/shaft to the nut that holds disks to atv.( 92015
NUT,16MM
92015-1465) in parts diagram
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
rcappie4
Jul 18, 2015 07:51 AM
