360 fuel in air box
Old Mar 9, 2015 | 10:19 AM
broke prairie 360's Avatar
Question 360 fuel in air box
need help I'm getting alot of fuel in the airbox? any help with that would be great
Old Mar 10, 2015 | 03:41 AM
Not familiar with the 360, but as a rule this is due to the float needle leaking. Sometimes it is just a bit of grit stuck to the needle tip, you can remove the needle and clean it. Sometimes it is the tiny plunger and spring, inside the needle, sticking and you will have to fit a new needle. If you turn the fuel tap off after use the needle won't leak much anyway. On most quads, a drain tube from the float bowl lets overflowing fuel run down to the ground, have you lifted that tube upwards?
Old Mar 10, 2015 | 08:09 AM
Default 360 fuel in airbox
very well could have but it fills when running also
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
