93 kawasaki klf-400b
Old Mar 29, 2015 | 04:52 AM
Steven Price's Avatar
Default 93 kawasaki klf-400b
I have a klf-400b 1993 electrical issue. I can hit starter button and get no spark but as soon as I let off button I get a spark. I have trouble shooted till I am brain fried. Can anyone help?
Old Mar 30, 2015 | 05:01 AM
I've had this problem on Hondas, and never cured it. The owners get used to blipping the start button as one of those sparks will "catch" and, once running, the bike is fine. It also works OK on the pull start as a rule. Some say it is caused by a dirty trigger coil on the alternator.
Old Apr 3, 2015 | 11:48 AM
sr.ruedas's Avatar
That is an interesting problem. I suspect that running the starter motor is drawing down the voltage of the battery too much for the CDI box to work properly. The starter may draw as much as 100 amps and take the battery down below 10V.
That points to a possible weak battery, but could also be a problem with a weak CDI box or a tired starter motor.
First thing to try is starting the quad with a big battery or 2 good batteries in parallel.
Old May 25, 2015 | 06:30 PM
MrSummit's Avatar
Steven, what did you find out?
I too have heard a weak battery can cause this. The starter pulls the battery down and the moment you let off the starter there is more juice to produce spark. I'm in the same situation with my Concours street bike. The battery is 5 years old but turns the engine just fine. I took the battery out of my atv and because the connections were on the wrong side, I had to use jumper cables to connect it. The concours started right up. I'm probably going to order a new battery this week.
My bike used to have regular coils, 1987 model, then I switched to stick-coils. I've been told the stic coils don't produce as strong of a spark as the OEM coils, reason being the oem coils had to fire a less than perfect air fuel ratio whereas the stic coils were designed for fuel injected bikes and therefore don't need to produce as strong a spark because the air fuel ratio is much better.
Old May 26, 2015 | 02:15 AM
The weak battery idea doesn't take account of the fact that CDI ignition draws power for the spark from the alternator coils direct, and will spark happily with no battery there at all. On some bikes, the Honda 450 is one, a faulty regulator will draw all alternator power, causing a loss of spark but I can't see a battery with enough grunt to turn the engine over taking too much out.
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
shimanok2
Jan 29, 2016 07:37 PM
wendal
Sep 15, 2015 01:50 PM
