2007 kawasaki bayou 250 NEED HELP
Old Jul 6, 2015 | 07:59 AM
Sjrpp's Avatar
Default 2007 kawasaki bayou 250 NEED HELP
So here is the problem . I recently purchased a 2007 kawasaki bayou 250 . I only payed 550$ for it because it needed some work . The day i got it home it ran fine all day long and the day after that . Then the next day i went to start it and it would bog down when given throttle . I have checked valve clearance , timing chain , drained tank flushed and put new gas in , and gone through the carb about 3 times and soaked it for about 2 hours . What im not getting is the fact that it starts up revs fine for about 10 seconds then starts bogging with any throttle this pattern repeats every time i shut it off and start it back up . Keep in mind it does smoke a bit so i didnt know if it might be low compression . I'm very mechanically inclined so any suggestion is help full .
Old Jul 6, 2015 | 01:01 PM
kwackermann's Avatar
Sounds like and electrical gremlin......................
Old Jul 7, 2015 | 02:19 AM
First off, if it is burning oil, has it fouled the plug? You say you soaked the carb, did you blow all the jets out and look through them? Check enough fuel is getting to the carb. Is the choke working properly? Some engines need choke until they get warm.
Old Jul 8, 2015 | 09:00 PM
Sjrpp's Avatar
Ended up finding out the problem . Turns out the generator for the battery was somehow causing it to do this. Have no idea how but it was.
Old Jun 2, 2019 | 07:25 AM
Marlon V Smith's Avatar
bad pickup most likely
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
Sep 23, 2015 06:23 AM
wendal
Sep 15, 2015 01:50 PM
