2000 Kawasaki Prairie 300 4x4 reverse override problem
Old Jan 1, 2016 | 09:28 AM
viponderosa's Avatar
Default 2000 Kawasaki Prairie 300 4x4 reverse override problem
My 2000 Prairie 4x4 reverse override isn't engaging it just bogs & sputters with no power. looking for any advise on a possible fix?
also my speedometer stopped working any ideas?
Old Feb 11, 2016 | 03:57 PM
Kymco 450i's Avatar
The override is just an electrical bypass, could be a loose wire or connection, check and clean all connections. As far as your speedo not working, probably needs a new speedo cable. I had a praire 300 2000 and my speedo quite working after about 4-5 years and found the speedo cable where it connects into the back of the speedo was never tightened at the factory and water got into the cable and rusted/broke the cable. Replaced the cable and used a cable lube tool every couple years and made sure connection were tight and never had another problem.
viponderosa
Dec 28, 2015 05:34 PM
viponderosa
Ask the Editor
Dec 27, 2015 12:48 PM
Clapper66
Dec 27, 2015 06:49 AM
Mark Smith
Dec 10, 2015 12:43 AM
itsbeal
Dec 6, 2015 07:41 PM
