Kawasaki 2009 fuel pressure problems
I haven't worked on Petrol (Gas) Mules, but on EFI systems the pump often has it's own fuse, has yours blown? The system also has a pressure release valve, this could be stuck open, however it is unlikely to drop the pressure to zero. A blocked intake filter would stop the fuel from coming through. Check if the pump is turning, either by listening/feeling for the vibration or removing it from the housing, if it is, check the filter and release valve.
kippstakes
Dec 30, 2015 10:02 AM
