Kawasaki bayou 300
#16
#17
Let's figure this out!
I alteady thought about it and work that choke plunger removing the cable out of the plastic, install back the choke needle, spring and a bbgun copper pellet to totally block the air comming in and just to be safe added rv siliccone to the outside hole so totally comdened the choke and did not make any difference so I do not think that is the problem. Back home in Costa Rica I have a kawasaki lakota 300 that did the same with the choke and it work perfect. I feel getting to the end of this problem and did order a new vostor cdi box to give it try if it is not the case I will tear top end and stator apart.
Last edited by Diogenes Olivier Alvarado Sandi; 08-13-2017 at 02:31 PM. Reason: Writting error
#19
