2004 Kawasaki Prairie 360, won't go from 2wd to 4wd
I have tested actuator and and actuator switch on handle bar. Both function normally. All fuses under seat are good. Is there a circuit breaker for this somewhere? I'm also concerned that the ignition module is faulty which I believe is where the voltage for the 4wd actuator comes from. I manually put actuator in 4wd so I can do some trail riding. Any guidance would be very appreciated.
lph008
Utility ATVs
03-14-2017 11:28 PM
Anthony Di Salvo
01-16-2017 07:18 PM
