Extremely need HELP!
Old Oct 7, 2018 | 07:42 PM
kaityluvs@gmail.com's Avatar
Default Extremely need HELP!
hey y’all.! I have a 05 650 brute force. I have tried absolutely everything I can. It is running on one cylinder. The rear will spark about 4-5 times then stop. I have replaced the stator, new spark plugs, switched my coils, put the stock cdi back in it. And I’m stumped! I need some serious help! Anyone?!
Old Oct 12, 2018 | 12:42 PM
armed hiker's Avatar
I don't know your atv but just some basics might help. Start at the plugs and work rearward.
Plugs -changed done
Plug caps?
coils - swapped done
power to the coil ?
If yes then head to the cdi box.
You say you put the stock cdi box BACK in why was it out?
know anyone with the same machine you could have them swap and test your units (CDI) ? You want yours on theirs so there is no chance of something not yours getting damaged.
Again I do not know your machine but it would not be uncommon for only one source coil to run the whole engine. On the other hand verify that there is not separate pick ups in the motor one for each coil, you can check a microfiche on various web sites to see this.
makeemfast
Jun 5, 2006 01:21 AM
poopypants
Oct 12, 2005 06:25 PM
pinheadedjoker
Mar 26, 2005 11:50 AM
WarriorDude350
Sep 2, 2000 02:24 AM
