99 Kawasaki pairie 300 no start after stator replacement
So i finally ordered a new stator from RMstator, it arrived and i go through the process of replacing it. I removed the pull cord cover, the pulley and the stator cover. I removed old stator and pick up coil.. replaced with new stator, new pick up coil...new gasket the whole 9 yards. Now i replaced the stator cover, i go to replace the pulley for the pull start and there is some ball bearing rolling around in the area where the pulley came out of. I replaced as many as i could find and put the pulley back on. I installed the key and tightened up the pulley. Reinstalled the pull cord and went to start it. It would not start, i tried the starter button several times and nothing. Pulling on the pull cord has same results. What am i missing??!! After trying several times with the starter button, it now just clicks when i attempt to start it. I have way more time and money into this quad for it to just junked. Someone please help for i am at a loss for whats wrong!!!!
