2002 kawasaki bayou 220
Old Oct 15, 2023 | 03:16 PM
BrianB94!'s Avatar
Default 2002 kawasaki bayou 220
I have a 2002 kawasaki bayou 220 and originally it was pouring oil out of the driveshaft but I fixed that problem and it was running and doing great, I cut it off and went out the next morning and it now has no power at all and blows the main fuse as soon as you hook power to it. I'm at a complete loss and do not know what to do if anyone can help it is greatly appreciated.
Old Oct 16, 2023 | 02:54 AM
If it blows the fuse with ignition switched off, it will probably be a faulty voltage regulator, disconnect it, then pop in a new fuse and see if it blows. If it doesn't blow, it will be a faulty regulator. To double check, the positive terminal on it should be open circuit when resistance tested against earth. If the voltage reg is not at fault, the most likely thing is the ignition switch itself, try disconnecting that and see if the fault goes off.
Atvwiz36
Nov 2, 2021 08:37 AM
hardball442
Apr 29, 2007 02:25 AM
EDISTORIVERRAT
Aug 18, 2005 03:55 PM
Seth
Jan 18, 2004 01:53 AM
