650 Prairie Alternator Capacity
Old Aug 5, 2001 | 09:19 PM
CaptNemo's Avatar
How many watts is the alternator on the 650 ??? I can't find a spec for it.
Old Aug 6, 2001 | 09:27 AM
PrairieDust's Avatar
I believe you can safely draw up to 60 additional watts. Its actually printed on the cigarette lighter style power outlet.
Old Aug 9, 2001 | 06:08 PM
GEEBEE's Avatar
I don't know how much power that the alternator will put out and you are right in that 60 watts is the max you can get out of the power outlet. There is a 5 amp fuse supplying 12vdc to the power outlet. Therefore, using the electrical formula, Power in watts=current in amps x voltage. In this case, current is limited by the 5 amp fuse which give us 60 watts (5amps x 12 volts = 60 watts). I suspect the alternator puts out more than 60 watts. GeeBee[img]i/expressions/face-icon-small-cool.gif[/img]
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 12, 2015 05:23 PM
