Mojave Pipe White bros. or BG??!?!
What pipe would be best for trail riding and racing around for fun...The White Bros. E-Series?? Or the big gun FULL race exaust? Any help will be appreciated![img]i/expressions/face-icon-small-wink.gif[/img]
The white bros e-series for the mojave does not have a head pipe. it uses the stock pipe wich is smaller and has ripples in the curve. The big gun is probably a good pipe, I have not used one. I almost tried one until I found out that the head pipe is tapered and is matched to the head port. This means you can not use a ported head effectively with the big gun, so I passed. If you do not plan to port or go extreme with cams this feature is probably a plus for low and midrange torque. My suggestion is to get the supertrapp ids2. It comes complete with head pipe and is available as a race series or quite series. The quite series is more restrictive but is quieter if thats what you want for woods. after about 10 disc the flow max is reached and additional disc will not increase flow. The racing series uses a straight through silencer and is louder. The more disc you put on it the more it will flow.
mrtidy
Feb 3, 2016 05:00 PM
