Prairie 400 2wd Rear Spring???
Old Oct 28, 2001 | 09:04 PM
TXRam's Avatar
A buddy has a Prairie 400 2wd that the rear end SAGS BAD. Is there any place that sells a replacement that is stronger (more stiff)? Is this a common problem on the Prairies?
Old Oct 28, 2001 | 09:37 PM
robbieg's Avatar
i have a 300 and i'm pretty sure they use the same rear shock.the spring is replaceable with a stronger one. hope this helps you. rob
Old Oct 28, 2001 | 10:21 PM
nyroc's Avatar
My bro has a '99 400 4x4, and we just hauled his 250lb and my 230lb carcases on it as we were riding into our hunting spot, and the machine did not sag a bit. Is the 4x4 different in the rear? Is it just springs? Pardon my lack of prairie knowledge.
Old Oct 29, 2001 | 01:04 AM
Slinger's Avatar
I have got the 300 4x4 and we've been usin' it to haul all our hunting stuff around. Now the rear end will compress when I put a load on it but won't rebound after everything is removed. I can lift the rear rack by hand and the wheeler will raise back to its factory height. I think either the shock is history or the spring is weak or both. What do you think?
Old Oct 29, 2001 | 11:14 PM
robbieg's Avatar
i would try a stiffer replacement spring
merryman
Jan 19, 2016 04:29 AM
Polaris5
Aug 29, 2015 09:11 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
Wnthunting
Jul 9, 2015 03:02 PM
