mojave carb tuning question
Old Nov 19, 2001 | 02:19 PM
mentalmojave's Avatar
I am currently running a 132 main instead of the dj 130 I got with my kit because I find that I am pushing towards lean with the 130 but with the 132 I'm pushing rich. Also when I have the bike in a taller gear like 4th or 5th at about 1/16-1/8th throttle to it and come on the throttle hard it is hesitant and once in a while has a very slight bog. I tried raising my needle one notch but then my mid was too rich. Any ideas anyone???
Old Nov 19, 2001 | 06:30 PM
gaff's Avatar
Hayman it sounds like you have to raise the c-clip, wich lowers the needle.
Remember at top all three circuts work together, sometimes you get stuck in between jet sizes, and in most cases you need to leen out one of the lower circuts to get the upper one to work rite.
Make sure your idle is good and not loping or going up and down. Turn out your air/fuel mixture screw untill it runs rough, then turn in the screw untill it runs rough, then find that happy medium spot.
Then raise your c-clip to the second groove down, now see how it runs.
Jmuddin284
Jan 19, 2026 07:16 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
