Talked with dynojet about lakota's
Old Dec 17, 2001 | 01:54 PM
  #21
mordr's Avatar
GrandmaYB-not sure how you can be rich(too much gas, not enough air) after allowing more air thru your engine, but not rejetting. Also, from what I understand, Dynojet and stock jet numbering has nothing in common, so a 134 DJ might not be too large compared to the 132 stock. I know that with every mod I had to jet up to get it right.
About what altitude do you live at? I really can't see how your plug can foul rich, when you have to be lean-how old is your bike?-could be rings-are you sure it is not oil fouled?
Old Dec 17, 2001 | 10:17 PM
  #22
GrandmaYB's Avatar
Thanks for info - didn't know stock and dynojet numbers didn't compare. How can you track changes? Is your 152 a standard or a Dynojet? Elevation is around 800 ft. Doesn't look like oil fouled - dry and dark. I actually had decent (not awesome) top end just a little less than before. I would think rings would be a significant drop on top. It's torn apart now to paint frame - will start working out the jetting after the holidays.
Old Dec 17, 2001 | 10:22 PM
  #23
gaff's Avatar
The dynojet jets are different from stock sizes.
The 2 1/2 turns on your air/fuel mixture as well as the new needle make it much richer over stock.
I've found on the lakota that a #130 gave me correct jetting, the suggestd jetting was a #138.
so keep going down and it will work out.
Old Dec 18, 2001 | 10:38 AM
  #24
mordr's Avatar
My 152 is actually a Mikuni jet, but I'm pretty sure that it's just like stock Keihin.
bigred20653
Oct 2, 2015 10:05 AM
mbriggs
Sep 13, 2015 10:47 AM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
