Help 650 Gas Leak??????/
Old Dec 25, 2001 | 07:07 PM
EXT's Avatar
EXT
Hi all came home from riding the other day and gassesed the 650 up.
The next day I could smell gas,I checked the bike and found gas all along the side of the motor on the left side.
I cleaned it up an figured I had just overfilled it.
I tried to start it and it seized up solid.I pulled on the strt cord some and it pulled over ok and started right up.
I pulled some plastic off and the gas is coming from the front carb somewhere.
I'm gonna take it in to the dealer to see what they can find.It only has 330km on it .
This happen to anyone else????
I figure it loaded up the cylinder with gas and this was why it locked up??
Old Dec 25, 2001 | 10:32 PM
Dianimall's Avatar
yes this happened to me the dealer said reasr rite side of the bikeabove the rear tire follow the vent tube from the tank there is a check valve take it apart put the parts in your favorate throwing hand and heave it as far in the woods as you can through remove your plugs crank it and change you oil .it vaper locked. i didnt pull my plugs i let it sit about i hour or 2 and it fired up . o put ck valve back together with no innerds
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
