i need a 2stroke genius please..tecate trouble
Old Jan 2, 2002 | 10:23 PM
NEMISIS's Avatar
ill look for the over flow..not to sure where it is at but i will look. thank you for the advice. i will check tomorrow and let you know if that is the case. thanks
Old Jan 3, 2002 | 12:35 PM
ejb's Avatar
ejb
I am a new member just sighned up first off you guys have a great form and very imforative, for your oil leak it could be a # of thing's if it looks like it is coming from ex.pipe ckeck your seal,and carb.jetting to make sure it is not to rich,and the back of your silencer will look wet and drippy if so repack silencer,your breather hose should be on top of your motor check to see how it is ran and see if it is leaking out of there if it is, check motor oil level if over filled drain to proper level, if still leaking from hose then i would think the crank seals are bad,if it looks like it is coming from left and right inner cases there is no gasket between those two cases they use silocone, if that is where it is leaking from it is probley the cases are warped,just keep a eye on oil level,and if you are new to 2strokes you have to run them hard , A good place to find 2stroke info is www.ericgorr.com he is 1 of the best 2stroke guy's in the country i hope this can help
Old Jan 3, 2002 | 01:56 PM
NEMISIS's Avatar
ok i might need to be more specific..the gumy oil (oil with some dirt in it) is on top of the water pump cover..the right front side of the motor. the oil lever was kinda low. so i do need to fill it..and this is a stupid question but does it have a oil filter? thanks for the help.
Old Jan 3, 2002 | 02:08 PM
brianc's Avatar
If it's on top of the waterpump cover, then it most likely is the power valve leaking. And no, the Tecate-4 does not have a filter. Just keep the tranny oil changed on a regular basis (like every other race, or 3-4 long recreational rides).
Old Jan 3, 2002 | 05:48 PM
  #15
NEMISIS's Avatar
thanks brianc..thats what i thought origanally..sorry i miss lead everyone. and thanks for the info on the firlter to.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
