Kawasaki vs.. Ford F-150
Old Jan 7, 2002 | 08:01 PM
RotGutBottom's Avatar
Thanks for all the good idea's... Here's a few more questions...
1. How do Glasspacks work?- and how/where are they installed? Do they lessen horsepower?
2. I was under the impression that dual-exhaust will hurt power and gas milage...
3. Does the "tip" effect the sound of the exhaust?- how so? Big=Better sound?
4. What's the difference with X pipe and Y pipe? How do they effect performance? is the X really in the shape of an X?
5. What do I have (stock) 2 pipes into 1 exhaust? What should I change it to?
-also- I'm considering a lift (6&quot... why do people do a combination on their lift... 3" Body and 3" suspension... why not do a straight 6" suspension lift.
Thanks for all your thoughts....
Brian
Old Jan 7, 2002 | 10:00 PM
bigbad400's Avatar
Get you some 3inch alumnized straight pipes. My b-law has them on his chevy 3/4 ton and man is it loud.
Old Jan 8, 2002 | 12:25 AM
alltoys's Avatar
Rotgutbottom
Gaff is right about your truck losing power off the start and reduce the problem put a "Y" pipe on your dual exhaust. If you want to do this by yourself. Paint your exhaust from the header for about 3ft. Take your truck for a run for long enough to burn the paint off to a place where the paint is not burned on the pipes. For example if the paint is gone from the header to about 2 1/2ft down the pipes that's where you connect your "Y". Cut holes and weld in the new piece of pipe and you will solve your initial power doldrums.
Old Jan 8, 2002 | 05:11 PM
nyroc's Avatar
I forgot to tell you, www.truckperformance.com has a large inventory of performance products for your F150.
They have smog legal, emissions fittings included, headers from gibson, jba and bassani.
The have blowers, intake stuff, chip stuff, NOS, power pulleys. Its really easy and friendly to order online from them.
Don't let what I said about my chip deter you. Mine may not have been set as well as they have done for other models.
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
shimanok2
Jan 29, 2016 07:37 PM
wendal
Sep 15, 2015 01:50 PM
