650 snorkeling???
Old Feb 22, 2002 | 06:15 PM
TexasDS's Avatar
I recently purchased a 650 and noticed that it was snorkeled pretty well from the factory. where i ride, there are a lot of water crossings and so far it has done great...just pop up the from end and ride, but does anybody know if there is a weak spot in the factory snorkeling that needs to be modified? i would hate to find out the hard way.
2002 650 Prarie
28" Outlaws
2" lift
Wheelspacers
Old Feb 22, 2002 | 10:18 PM
coolinthewoods's Avatar
NICE SET UP! I havent got to ride my in any deep water yet it was all frozen when I got mine. No one has complained about the snorkel system on it yet,but people have extented some of the vents.
Old Feb 23, 2002 | 10:59 PM
northarkie650MUDD's Avatar
i can go rack deep and be fine, the only weakness is the tranny exhaust, no big deal.
Old Feb 24, 2002 | 05:20 AM
Hey northarkie650MUDD- could you explain how you snorkeld eveything, Pleaseeeees! just like to get a idea.
Old Feb 24, 2002 | 10:37 AM
the tranny exhaust is all i have done so far. it was a real pain to find something that would fit water-tight over that oblong hole, but i found something that would. go to a hardware store, and get a black rubber 2" to 3" adapter for pvc pipes. with a little stretching the 3" side will fit over the opening then all u need is some 2" pvc or hose(what i use).
Old Feb 24, 2002 | 04:58 PM
Are you calling the clutch cover upper vent,"tranny exhaust" the rubber boot,the one you have to pull to replace the rear spark plug?if so, OK! And were did you run it to.
Customer Service #1
May 15, 2020 08:46 AM
Steeldon
Sep 9, 2015 09:38 AM
switzomatic
Aug 24, 2015 12:57 PM
Ean
Aug 20, 2015 07:13 AM
Cantbuytime
Aug 17, 2015 06:33 PM
