longer mojave clutch cable
Old Mar 1, 2002 | 11:42 AM
mojaveaddict's Avatar
I remember a post or two in here where someone was looking for a longer clutch cable for a mojave that they put wider bars on. I just recently ran into the same problem and found some longer cables. Thought i would share the info. I made a custom chromoly stem with a antivibe clamp for my mo and put on cr bend bars. The taller stem and wider bars mabe me have to run my clutch cable at a more direct route and i did not like it. I could not run it through the custom cable guide that i made that mounts on the stem pivot. I went on the search and found that a warrior cable will fit perfect and is about 6 inches longer than the mo cable. It also has a thicker cable inside so it is stronger and will stretch less. 6 inches more works ok for me but is a little too much and would be way to much if you only add wider bars. But i also found that a ninja 600 and a ninja 1200 cable will fit. I could not find anyone with one of these in stock to get a measurement on the length, but i would have to believe that they are a few inches longer than the mo.
Cummins Driver
Sep 11, 2019 01:22 PM
cdstang
Aug 31, 2015 07:52 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
