**Mojave Gearing Question**
Old Apr 10, 2002 | 05:46 PM
mojaveman1's Avatar
not with the plastic case saver and maybe it wouldnt even with that off but in the capperal catolog it says 11 to 17
not to say that i am always right but i am always very informed and up to date in my information i dont just pull things out of the air i am looking for advice not for somone to tell me how it is and THERE IS 11 to 17 AVAILABLE
Old Apr 10, 2002 | 06:13 PM
mojavekid13's Avatar
there is no such thing as a 17tooth sproket for a moajve!THERE IS NO IF ANDS OR BUTS!!!!!!!!U cant get one and even if u could it wouldent fit!!!!!and iam VERY VERY informed about my info to.So dont tell me "iam so informed and i know that there is a 17 tooth"Can u also do a backwords wheelie on your mojave!It is 4 wheel drive RIGHT?
Old Apr 10, 2002 | 06:18 PM
Sprocket's Avatar
A 13 tooth countershaft sprocket is the largest size that will fit due to the case configuration. There is simply no room for anything larger because the counter shaft is recessed on the back of the side case and there is not enough clearance around it. I don't know why there are larger sprockets available but believe me, 13 is max!
Old Apr 10, 2002 | 06:20 PM
SEE I told u so!!!! I know more about mojaves them most people!!!!!
Old Apr 10, 2002 | 06:21 PM
  #15
Well some outher people proble know lots to but i know way more then U!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!MOJAVEMAN1
Old Apr 10, 2002 | 08:25 PM
  #16
mojaveman1's Avatar
man get a life you made absolutly no point at all all i said is that they probably would not fit but i seen them in the magazine
and i was also right they will not fit and like i said all i am looking for is advice not some little kid that thinks hes smart i want to no wut to run
Old Apr 10, 2002 | 08:26 PM
  #17
Sprocket's Avatar
Take it easy guys. Acting belligerent accomplishes nothing. If someone is misinformed then the best approach is to politely provide the correct information. If they choose not to believe you, then so be it. But hurling insults back and forth just shows immaturity. Nobody wins a pissing contest.
Old Apr 10, 2002 | 08:29 PM
  #18
mojaveman1's Avatar
still no one has given me any advice
i want speed but i dont want it to be so terrible that i cant run through wooded trails
and you are probably right it wont fit nore work at all i just said that i seen it and who cares if it wont work than tell me wut will
Old Apr 10, 2002 | 08:32 PM
  #19
Who are u calling "little kid" iam 16 almost 17.My name is mojavekid13 because thats my racing NUMBER!!!I have been around bikes since i was 4.I road my first mojave when i was 10!! so **** off JA
Old Apr 10, 2002 | 08:33 PM
  #20
13/41 with 20' tires i told u already ,,thats the best gearing to run
