650 Pumping oil up a vent tube need help
Old May 9, 2002 | 02:39 PM
JohnEagle's Avatar
my wife was riding my 650 a few days ago and when she brought it back the top cover and the engine was covered in oil. i took all the plastic off and found the oil was pumping up through a vent tube in the handle bar cover. it looked like the far right one was wet. i dont know which breather that is so i need some help to find out which it is and why its doing that.
Old May 9, 2002 | 04:47 PM
nyroc's Avatar
From what I can see in the manual, the right one is the rear diff breather. The front diff is next to the left, then the radiator fan motor breather, then the 2wd4wd actuator motor breather is far left.
Did someone over fill the rear diff? Or put the wrong stuff in it? Does you wife drive with her foot on the rear brake lever? I'm not sure what that does, but possibly overheating the rear diff, I doubt it though.
You say it has nothing to do with the engine's oil, but is the engine oil ok? Not overfull, no water?
Old May 9, 2002 | 07:40 PM
JohnEagle's Avatar
Well i dunno if my old lady was riding the brake or not i didnt even think to ask. my quad had been sunk in a lake by a friend of mine and he was supposed to change all hte fluids out but i did notice it looked like the oil has some water in it. i know he changed the oil in it cause its looks good. but i dunno about the diffs. that could be it. i will check into that tho. thanx bro
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
