High altitude jetting help 650 P
This thread is interesting to me, as I have posted before about altitude as I plan on taking my P650 Elk hunting at high elevation this October (if the whole dang state of Colorado doesn't burn) and I am trying to find out what I have to do for 10-12,000 feet. My earlier info is leading me to just try the DiamondG snorkle and a high flow air cleaner element as the bikes are jetted lean to begin with and this should help to lean it out at elevation even further. I was leaning toward doing this as I am satisfied with the power at Minnesota elevations, and I didn't really want to go into the carbs, as I am not really a great carb guy. From what I read here, it doesn't sound like too much work to change the jets. Is it? How much time does it take to change the jets? Can somebody who is somewhat mechanically inclined do it without screwing things up? Thanks for the info.
Todd M.
Minnesota
Todd M.
Minnesota
#15
bonzi:
I live in the Reno area and still run the stock jetting in mine. I bought my scooter from a dealer in Fresno, CA. and they are jetted quite lean to begin with in Calif.(Cal emmision requirements). I ride up over 8000 ft. quite a bit and have not had any problems with the scoot loading up or running lousy. Plugs are burning OK, just a little on the dark side.
If I were you, I would wait until you get out here and see how it runs. Might save you a rejetting hassle. However, if you enjoy wrenching, go for it.
Also, one other thing. There are fire restrictions in effect out here at this time. You need to carry an ax, shovel, and a gallon of water if you go off road. And, if you cross over into Calif., you'll need a non-resident sticker($20).
#17
Rather than buy the dynojet kit you could just get the main jets that Kawi recommends running for different altitudes. They can be changed by only removing the carb bowls which doesn't require plastic or intake system removal. I'm fixing to do mine with the kawi main jets and I'll post how long it takes and how hard it is to do.
#18
Bonzi
Yes I am running stock clutching, I have purchased the dyno flow kit and found out that stock setting was more than adequite. I have modded my muffler to Nyrocs specs except I used a larger drill bit and more holes. I found that the new jets from dyno actually hindered my performance. Understand this I am at 2200ft and ride continually at 3000-8000ft. From what I was told the bike is somewhat lean from factory and jetting down isn't the way to go. I am at stock setting with my factory jets and needles and my performance is considerable. A whole 10.35% increase in power and overall speed. I wish I had more time I would get into the nitty gritty of this subject. This weekend is a long weekend for us in Canada and I have just put the green machine back together. From all the mods I have done I expect to kick some Polaris Butt. I did a post almost a month ago matching the 650 with a 700 as with my 28in Outlaws and my buddys bike being stock I thought it would be equal. Sure enough there wasn't much advantage at all just inches is all I acheived in victory. Nothing to write home about. Except now of course. When I get back I will post all my mods I have done and let you all now how things turned out
As for the clutch I have been lucky I guess all measurements are within specs. Although I can see with this increased horsepower I might have to do something down the road. DiamondG is in what I think the forefront for mods to the Kawi especially the clutch, snorkel (for which I have ordered), a CDI BOX and later down the road and a cam. The biggest ones right now are the air box and the muffler and the jets. To get more power you must increase air flow, fuel mixture and exhaust thats pretty much it. KISS (Keep It Simple Stupid) trust me any thing you do to these parts will drastically inhance your performance. 10 percent of a 43horspower engine is 4.3 ponies doesn't sound like much but add that to the torque side and it is substantial.
Keep the sunny side up.
#19
Ok. Still getting black plugs after a ride for a few min or even all day. I have went with "NGK" hotter plug, nothing! Went with a 42-1 mix with golden spec., nothing! Cleaned air filter, nothing! Adjusted air screw out 2 full turn from lightly seated, nothing! I took the neddle out in the carb from the top, and moved the clip on it up one, the book said it would lean it out, nothing! I am about 3,000 feet above sea level, I noticed the stock main jet is a #148, I was told by the locals to go with a #145, due to the sea level, TRUE??? Will performance go down or up or??
HELP!
Ron
HELP!
Ron
#20
Steeldon
09-09-2015 09:38 AM
