lakota clutch replacement
Old Jul 15, 2002 | 07:26 PM
steve646's Avatar
ok ive got clutch slippage are these clutches hard to replace on your own and are any special tools needed and should i use dealer replacement parts or aftermarket which would be better
Old Jul 16, 2002 | 09:47 AM
gaff's Avatar
Steve,
I used K&G factory clutches (800-821-7657) It's less than $50 for kevlar friction disc and heavier clutch springs.
The clutch is very easy to replace. I did use a impact on both clutches retainer nut. Not realy sure if you can get them off without a impact.
The centerfugal clutch needs pulled and the glazing cleaned from it's drum. I used a dremmul with a 60 grit drum sander, worked perfect.
Once you replace the clutch performance is much better.
Oh I have a set of springs and clutch plates, email me if you want them.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
